Portfolio area Application Server
Products IDE
Created by Rob Budak
Created on Oct 3, 2024
IDE indicator for nearing the per-object Attribute limit
The MES OCO User Guide mentions this important note:
An entity can have a maximum of 50 jobs. However, there is a limitation within System Platform that an object can have a maximum of 5000 attributes.
Hitting this limit is quite feasible when using OCOs and on objects using lots of alarming and I/O features.
An in-IDE warning of how close you are to this value, sort of the like Industrial Graphic Performace Index, would be a helpful addition to convey this limitation. It's already possible to see the attribute count if you open the Filter panel, but the 5,000 limitation is not apparent until it's already hit.
Perhaps a progress bar with a counter could appear in the header of the Attributes panel when you are over a certain attribute "warning" threshold. See the attached "ExampleProgressBar.png" for a mock-up of how this could look in the editor.
    Oct 3, 2024
    Your idea has been reviewed and may have been edited to remove any perceived sensitive information. It is now publicly visible for others to see and vote on. If you are uncomfortable with this, please contact us to reduce the visibility level.
  • Admin
    Ernst Van Wyk
    Oct 3, 2024
    We can possibly incorporate this into the idea to provide an Object Performance Index: https://products.feedback.aveva.com/ideas/APPSERVER-I-167
