Portfolio area Application Server
Products Compatibility
Created by jacki denis
Created on Mar 19, 2025
Modify in runtime the text for an attribute with Data type Internationalized String
Since 2023 R2 release, some string attributes are now with the Internationalized String data type. And the inherited negative effect is that we can no longer edit the text in runtime for a description attribute. Indeed, as part of a continuous improvement of our SCADA system, we have left it possible for some SCADA's users to modify the description of certain data. since we migrated to 2023 R2, we can no longer do this.
Could you restore the functionality of changing the text of an attribute to runtime even with the Internationalized String data type?
    Mar 20, 2025
    Your idea has been reviewed and may have been edited to remove any perceived sensitive information. It is now publicly visible for others to see and vote on. If you are uncomfortable with this, please contact us to reduce the visibility level.
1 MERGED
Allow Writing the Attribute Description at runtime.
Merged
The Attribute description is used by default for an event log when writing to it from the HMI. I don't want to have to import this field for every attribute that could get logged in this way. Allow it to be set with a script at runtime so it can b...
Jeff Scheer over 1 year ago in Application Server / IDE
