Status Planned
Created by Vitali Unke
Created on May 22, 2025
Abnormal state enumeration in ADE
Big Picture User Experience
This enhancement will improve the point-to-point verification process by aligning the state-enumeration numbering with the states defined in the messageSet table. This will ensure that the field technician and the SCADA operator are configuring the correct abnormal states for digital points to alarm against by either using the state name, or the raw number
Detailed Description
During Point to Point Verification, the field technician communicates essential information to the SCADA Database administrator. For multistate points, the technician may report abnormal states configured in the device using decimal equivalents programmed in the field device. The SCADA Database admin must configure these points to match the decimal numbers in the PLC and ensure the correct state name corresponds with the raw decimal number. Below is a PoC that outlines the abnormal states. The enhancement is to display the raw number to the left of the enumeration state, because without this, , it will be extremely difficult for the field technician and the DB Admin to confirm the states are one and the same, especially when configuring multistate points which have a large messageSet with non-unique message state names. For example, look at states 10 and 12 below:
Figure 1 - A Proof of Concept showing the new raw number to the left of the enumeration name. Without this number, states 10 and 12 appear identical.
Currently, in order to verify alignment, the SCADA Database Admin must check the MessageSet Table of the selected record. Due to the lack of standardization across the organization, configuration becomes challenging with varying numeric values for the same state. It would be beneficial if the ADE form that is used to configure abnormal states included the decimal numbers as well as their corresponding text states from the MessageSet.
Business Value
Improve Point to Point Verification by eliminating a source of ambiguity in the SCADA interface, which simplifies the effort of configuration and reduces risk of human error.
Acceptance Criteria
  • The raw value of the messageSet state should be printed on the ADE form alongside the corresponding state.
  • Both Status and MultiState points should be enhanced to support this behavior.
  • User Documentation updated.
Out of Scope
No other place will exhibit this behavior. Alarms, events and all other Visual representation of states will remain as is today. Customers are able to modify the baseline screens to add this and any other information as they desire.
Assumptions
This is a cosmetic change to the abnormal state config screen only. No additional logic, sanity checks or functions are required. Config change events are not changed.
Dependencies
None Identified
Upgradability
No issue or concerns have been identified. This is just an ADE form that reads the data directly from the DB.
PSR - Performance, Scalability, Resilience
No PSR impact as this only enhancement is only on the ADE form edit. There are no processing, alarming or any other places that his behavior will be observed.
NFR - Non-Functional Requirements
none identified.
Mock-up / Supporting Information
Expectation
To verify alignment, the SCADA Database Admin should check the MessageSet Table of the selected record. Due to the lack of standardization across organization, configuration becomes challenging with varying numeric values for the same state. It would be beneficial if the ADE form used to configure abnormal states included the decimal numbers as well as their corresponding text states from the MessageSet.
Idea Type Improvement
Product value score
6
Work in
OASYS-968 Abnormal state enumeration in ADE [TCE]
Work status
  • Admin
    Vitali Unke
    Sep 2, 2026
    This has been confirmed to be avaialble in Q1 of 2029.
