Status Future consideration
Created by Jake Hawkes
Created on Mar 1, 2021
Offline Rate Integration
Customers on 7.5 system often had a small change made to vdb_rate.cpp, allowing integration to continue even when a point was not fresh, using its last good rate value.
This allows calculated volume integrations to match more closely with what other billing applications in use are reporting, reducing the size of the corrections.
There used to be a monitorRate application to handle this, and it has survived in the Delivery groups, and recently again by the Extensions team for handling rate points updated via RBE
