Status Already exists
Created by Bradley Tomanik
Created on Jul 31, 2023
GroupArea in the area table only contains the first 20 groups
Do we actually have a limit of 20 groups per area?
Some testing has shown that one can add more then 20 groups into an area. The GroupAreaJoin table populates all of them correctly however the "group[0-19].name” array-field in the area table only contains 20 groups from the full list found in the groupAreaJoin table.
Expectation
If we are limited to 20 groups, please say that. If not, why does the Area table only contain 20 groups if there are more configured?
Idea business value
Need to know if there is a limit or not, as it will impat some legacy customers who are using this AOR with more than 20 groups.
Idea Type Investigation
User Persona SCADA Administrator
  • Admin
    Jake Hawkes
    Jul 31, 2023
    AOR data is mastered in ADAM, and then periodically synchronised into realtime for use by realtime processes.
    There is no hard limit in ADAM for the number of groups in an area.
    The sync code is limited by the size of the groupArray field in the area table, which is limited to 20 elements, hence the apparant limit.
    However, the data synced to Realtime is not not when determining a users AOR - only data straight from ADAM is used for this.
    In other words, the groupArray field in the Area table should be deprecated, and all users should use natvie ADAM APIs instead.
