Status Reviewing
Created by Jake Hawkes
Created on Oct 6, 2023
Combine Tag & FlexTag into a single tagging solution
We have two tagging features: legacy, and Flex Tag
What are the differences? Do we need to keep both?
I've heard from a few people that they are recommending to customers to not use FlexTag, and to go back to legacy tagging due to the various descrepancies and missing functionality in FlexTag.
Differences and descrepancies:
Known Issues:
Other requested enhancements:
From R&D:
I recommend the project uses Flexible Tagging instead of the default Tagging.
Flexible tagging allows for greater customization of tags. It supplements, not replaces, regular tagging and can only be used with Analog, Status and Multistate tables (and in some versions, the Rate table in a limited capacity).
Flexible tagging is a feature that allows for greater customization of tags. With flexible tagging (FlexTag), you can configure the exclusivity of tags, group tags together for mass modifications, set priorities for FlexTag types, customize tag icons, and more. With flexible tagging, you can also attach multiple tags to a single record.
Flexible tagging is not enabled by default. Although the FlexTag Summary can still be accessed from the ezXOS navigation menu, the system will not acknowledge any FlexTag configuration changes unless the registry variable is turned on.
Flexible tagging also offers the ability to define a wider range of tag types:
- Inhibitive (cannot override)
- Warning (can override)
- Maintenance
- Informational
There seems to be a big disconnect here. The above text was found in Jira, but appears to have been lifted directly from the HMI controller guide. Which explains why they think these two things are complimentary, but in the backend they appear to be separate things.
To figure out:
  • Are we capturing sufficient audit trail information?
  • Any usability or scalability enhancements?
  • should we even have the option to turn this on/off? Why do we continue to ship two different tag control panels?
To be rationalised (from OneNote Tags vs. FlexTags (Web view))
Expectation
One super-set tag function with all features from both legacy and Flex tag, that supports the later versions of the HMI.
Idea business value
Customers are not able to adopt the better Flextag until it meets feature parity. This hold them back from modern HMI adoption, and generally holds them back on legacy features.
Also, we benifit from maintaining only one tagging solution as we continue to improve more of the CRM
Idea Type Improvement
Product value score
17
Work in
OASYS-E-129 Combine Tag & FlexTag into a single tagging solution
Work status
