Status Reviewing
Created by Jake Hawkes
Created on Oct 6, 2023
Alarm should be generated when Omnicomm stops polling a connection record due to being added to the bad hosts list
Create an alarm when omnicomm detects DNS issues and puts a connection offscan.
Expectation
When omnicomm puts a connection offscan due to its IP address failing a DNS lookup, there should be an alarm generated to bring this to the operators attention.
Idea business value
This happens rarely (and the root cause of the 'network blip' was not given) but when it does, it is quite disruptive as the operators dont immediately know (although the points where stale?)
Idea Type Improvement
User Persona Pipeline Operator, SCADA Administrator
Work in
OASYS-540 Alarm should be generated when Omnicomm stops polling a connection record due to being added to the bad hosts list
Work status
  • Admin
    Jake Hawkes
    Oct 6, 2023
    Customer reporting this has a scripted workaround, and is also investigating the use of the Age Watchdog to replace the script moving forward.
