Status Future Consideration
Portfolio area Plant SCADA
Created by Eduardo Samper
Created on Apr 28, 2022
Access Anywhere two-factor authentication
Access Anywhere is not compatible with third part apps with two-factor authentication. (I.E. Radious)
Ericom support confirmed Access Now does not support Radius.
RADIOUS needs a two-factor authentication option, so it is not compatible with Access anywhere natively.
End customer is unable to set third part apps with two-factor authentication to work with Access Anywhere.
Idea business value
Make Access Anywhere compatible with third part apps with two-factor authentication. Right now, it must be done through server or VPN connection which allows for 2FA and then connect it to Access Anywhere.
  • Admin
    Nathan Slider
    Oct 4, 2022
    Plant SCADA Two Factor Authentication. R&D Teams are collectively working on this corporate initiative for the portfolio with research and design occurring at the moment, which will allow all products to consume this common feature.
  • Admin
    Nathan Slider
    Oct 4, 2022
  • +8
