Portfolio area Application Server
Created by Ernst Van Wyk
Created on Jul 28, 2024
Expand Auto-binding capabilities
Auto-binding has the potential to improve productivity significantly by removing the need for complex IO referencing scripts as well as allowing users to test IO assignment in runtime. Auto-binding today can only use the assigned IO device and Scan group with the object name and attribute name, this needs to be more flexible
The idea would be to improve or expand existing aspects of the AUtobinding functionality:
Aspect I: The IO reference syntax
Today the Auto-bind syntax looks like this: <IODevice>.$TemplateName.AttributeName
  • <> to denotes variables used to assemble the IO reference. These can be special reserved keywords or System Platform (AppServer) attribute references.
  • This needs at least four reserved keywords
    • <MyDIObject>
    • <MyScangroup>
    • <IODevice> (this already exists, but since <MyDIObject>.<MyScangroup> will have the same result, we can deprecate it if we want)
    • <Attribute>
    • Consider other building blocks as well:
      • <ObjectName>
      • <HierarchicalName>
      • <AreaName>
      • etc.
  • Provide a mechanism to allow using object attributes directly as well as plain text. This means you can build an Input source as:
    • <MyDIObject>.<MyScangroup>.<me.AnotherAttribute>.<Attribute>.Array[<me.ArrayIndex>].PV
Aspect II: Design-time experience
  • The IO Devices pane usage remains the same
    • User can assign an object to a Scan group on a specific DI Object
    • We should allow a user to designate a default DI Object and Scan group (similar to default area, engine and platform)
  • The Mapping pane should function as it does today, that is: it should attempt to use the assembled IO reference, connect and show live data.
  • Danny Power
    Jul 7, 2026
    Would be great to be able to "trim" the resulting autobind address. For example, in situations where there are multiple plants with the same PLC program with item names like LIT101.pv. When all plants come into Galaxy they get full tagnames like Plant1_LIT101.PV, Plant2_LIT101.PV and resulting AutoBind does not work. Beign able to remove the header automatically would benefit a lot of PLC programmers
  • Jim MacDonald
    Nov 22, 2024
    I like the idea. How would this relate to the work done by Mike Brost (?) with "Rule based IO formatting"? See attached
1 MERGED
Hierarchical or object use for I/O reference naming
Merged
I would like to see the option of choosing hierarchical or object name reference when using IO source autobuilding. This could be a simple check option in the I/O subwindow. I believe this will limit a fair amount of IO overriding. For example in ...
Dean DeGrazia over 2 years ago in Application Server / IDE
