Enhance Archive & Cleanup to be multi-RT-single-HIS aware
Big Picture User Experience
Archive and Cleanup do work against the server configured as the Secondary Computer for the Archive service, even if the Secondary Computer is Hot for the Archive service.
Further, for Split Realtime systems, there needs to be a way to specify which system the JSH entry should launch these processes.
Background Research
The rts_cleanup.csc seems to look for the Primary Computer to execute the BLT against. This means if the Primary Computer is down, it is not possible to run cleanup. This also seems to be the case for rts_archive.csc. This means these jobs are not redundant.
For some customers, the RealTime and Historical/Archive services are on different systems (the reason being we have multiple RealTime systems pointing to a single Historical system), so they need to specify in JSH which system cleanup should run, otherwise it will look by default at its own system where there is no Archive service.
the real problem we are seeing is that rts_cleanup.csc cannot run properly if only the Archive Secondary Computer is up. It looks like the BLT cleanup can only be executed against the Archive Primary Computer’s BLTHost. If we run it against the Archive Secondary Computer (either by bringing down the Primary Computer or pointing it to the Secondary Computer with ‘-A’) we get an error and there is no record of cleanup running.
Detailed Description
To be confirmed.
As a SCADA administrator, I need archive to run against the hot Archive Service, regardless of which of the pair is HOT. I need this so that I do not have to fail over the Historical or Achive Service for the Archive and Cleanup processes to run.
As a SCADA administrator, I need to be able to specify the location of the output from the archive process.
Business Value
Customers with split systems need to be able to schedule archive correctly.
SQL infrastructure has evolved to where it is no longer the case that the archive device is only ever connected to one of the Historical nodes.
Target Version
ES24 or SP1
Customers System / Architecture
Size: Small, Med, Large and x-Large
Topology: Multi Site, Split system, and Custom Enterprise
Any Unique configuration to note?: Multiple RT to single HIS, but also the more regular topologies
Has this functionality been delivered before?: No
Expectation
To be confirmed.
As a SCADA administrator, I need to be able to specify the System Name in which I want the Archive/Cleanup processes to run. I need this for when I have a split Realtime System.
Work in
OASYS-356 Enhance Archive & Cleanup to be fully redundant, and multi-RT-single-HIS aware
Work status
    • Admin
      Jake Hawkes
      Oct 6, 2023
      IMS 2818258 will adress the redundancy issue to archive.
