Add 'Workstation Administrator' Role to Active Directory
Big Picture User Experience
Following the Principle of Least Privilege, AD-Tiering and now Enterprise Access Model , add 'Workstation Administrator' Role to Active Directory to enable a separation of duties between server administrators and desktop/workstation administrators.
Detailed Description
Customers require the ability to separate those that only need to administer workstations from those that also administer the servers.
This new role would be allowed to:
  • Install and configure new workstations as well as reinstalling and replacing existing workstations.
  • Troubleshooting workstation related issues including shutting down and rebooting workstations.
  • Joining and removing workstations from the domain.
The new role should be:
  • a member of Local Administrators group
Customers wish to be able to assign users with this role into custom AD groups. It has been noted that this may not be possible due to restrictions in place.
AIT uses local administration on the first DC to build the domain and run OADC, which creates the dnaInstaller account.
Then, AIT use dnaInstaller to install servers and workstations, and promote the secondary DC. I.e performs configuration in tier 0,1,2
Then, all accounts and groups are moved to a tier, and restricted to that tier.
dnaInstaller goes into tier 1, meaning that it cannot be used to install into tier 2
We need an admin role with sufficient privs that is limited to tier 2
Acceptance Criteria
Ability to assign the new Workstation Admin role to existing DNA users.
Ability to assign users with the new Workstation Admin role to custom AD groups.
Business Value
Security is evolving, and this practise aligns with best practices from Microsoft, who call it "AD Tiering".
The best way to protect your systems is to ensure that privileged AD accounts are never used for administration of devices that don’t have the same level of trust as domain controllers.
https://www.beyondtrust.com/blog/entry/protect-privileged-active-directory-credentials-using-tiered-administrative-model
Target Version
Target version for this feature: TBD
Version the customer is on or consuming: Various
Customer, Project, and Deadline Details
Customers (names/projects) that will consume this:
Three customers are already doing this via project customised AD/GPOs.
Request is to ship new product with this design.
Deadlines and Commitments: None.
Commercial and/or Contractual Impacts: None identified, although we may already be marking compliance to this as a requirement in tenders.
Customers System / Architecture
Size: Small, Med, Large
Topology: Single site, Multi Site, and Enterprise
Any Unique configuration to note?: No.
Has this functionality been delivered before?: Yes - see above.
Out of Scope
Assumptions
This is possible without dramatically changing the existing AD/GPO design.
Dependencies
AIT
Another new role has been requested: the ability to request a POLL from a read-only user in the DSS.
ES2023 will have considerations for installing into existing Enterprise SCADA domains.
Upgradability
The new role can be added to an existing domain without breaking the existing system.
Using the new role on the latest version of Enterprise SCADA in the same domain as older versions will be documented as either supported with manual steps if required, or not supported.
PSR - Performance, Scalability, Resilience
Important PSR aspects for this feature? None.
What if there are 10,000 of these? n/a
How quickly is this expected to react/respond? n/a
Does this impact failover / mode switch? no
Is this assumed to have performance impact, or not? no
NFR - Non-Functional Requirements
Operating System: OS2022
Other AVEVA products: none
3rd Party products: none
CPU / Memory / Disk requirements/constraints: none.
Risks/Mitigations
None
Work in
OASYS-417 Add 'Workstation Administrator' Role to Active Directory
Work status
