Status Shipped
Portfolio area Application Server
Products Development IDE
Created by Ernst Van Wyk
Created on Jul 28, 2024
Template import/export
Developers often have the need to create Templates in bulk and to configure them. A tool is needed that abstracts the complexity of the GRAccess toolkit but is more [flexible] than Object CSV import/export functionality.
In addition to this there is also a need for a text-based configuration import and export functionality that can be utilised by Git repositories to facilitate version control.
The intent is for a user to be able to have 2 experiences:
  1. A simple import export capability that allows a user to quickly create or modify a template with:
    1. Attribute names
    2. Attribute types
    3. Attribute values
    4. Attribute Description
    5. Attribute Engineering Unit
  2. A full-blown Import/Export facility:
    1. The ability optionally configure features and their parameters e.g.,
      1. History
      2. IO
      3. Alarming
      4. Statistics
      5. etc.
    2. The ability to link content to the template:
      1. Graphics
      2. External Content
      3. Layouts
    3. The abilitiy to optionally create/modify Wizards - this could be done in a supplementary text file
The workflow should allow
  1. Export existing Templates to a text based configuration file (e.g. CSV, XML, or JSON)
  2. Create/Modify Templates in bulk by importing a text based configuration file (e.g. CSV, XML, or JSON)
  3. The following Template features should be supported:
    1. Attributes
    2. Wizards
    3. Scripts
    4. Linking Content
      1. Graphics
      2. External Content
      3. Layouts
  4. This method should either align easily with the existing CSV import/export to create instances or augment it
  5. The Graphic Import/Export API can be utilised to allow creating graphics directly on templates
  6. In an ideal world, the combined export will result in a file or set of files that could be stored in a git repository (on-premises or in a cloud repository such as GitHub) and that could be used to monitor and manage changes
  • Piotr Polok
    Aug 26, 2026
    Love it!
  • Andrew Drane
    Sep 9, 2025
    YES! I recently had a support ticket open to discuss this. The GRToolkit is poorly documented and relies on some old programing technologies that make it very difficult to work with. This create/modify a template from spreadsheet or json, or xml should definitely exist. The amount of time I could save importing from PLC UDT spreadsheets instead of manually creating templates would be HUGE!
