Created on Feb 8, 2022
Alternate timeseries hourly averaging algorithm
Enhancement request to either allow integrators to modify timeseries averaging algorithm or provide hooks to allow integrator to modify the operation.
We implemented an alternative timeseries averaging algorithm on many installations. Prior to binary release in 2021 this modification was completed through direct modification of the collect code. The integrator would change averaging to be based on GOOD DQ samples only, and storing of average counts (the number of GOOD DQ samples used to calculate the average value) within the TimeSeries summary records
  • Admin
    Jake Hawkes
    Feb 8, 2022
    Seems like an enhancement to make collect only consider good DQ in the average would be simpler and more effective here.
    Are there any other requirements lurking here that aren't listed due to the request to make this extensible?
    There is a new data export framework called HPDEF (High Performance Data Export Framework), which baseline itself will use to develop a new Exception Collect plugin, for the purposes of being able to put any field on exception collect, instead of the hard-coded list it supports today. The HPDEF provides plugins with a complete copy of the record before and after the data change that triggered the framework.
    So, you could implement your own plugin that performs collect according to your desired business logic, and then implement your own historical aggregation in Historical. Coupled with the Krunch Pipeline, you could calculate the same custom aggregates in Realtime.
