Request for year to be added to the runtime structure
We've previously added an additional "year" field to the runtime structure to track hours per year for a 7.5 project. I'd like to request an enhancement to OASyS 2021 to add "year" to the runtime structure please. I see that there's a runtimeyear.json file that seems to have year but it only appears to be used by compressor. Or is there a way to get runtimeyear to work with other telemetered tables that I just couldn't find? (I searched through the docs but no mention of using it with other tables).
Copied from OGPM-3183
Expectation
Idea business value
Project enhancement from 7.5 version.
Idea Type Improvement
User Persona Developer / Integrator
Work in
OASYS-478 Request for year to be added to the runtime structure
Work status
    • Admin
      Jake Hawkes
      Sep 28, 2023
      Will close due to no activity
    • Admin
      Jake Hawkes
      Jun 2, 2023
      Bump
    • Admin
      Jake Hawkes
      Feb 22, 2022
      Thanks Natalie - which tables are a must-have for you for this feature? Would it be calendar year or some other epoch?
      I notice you are requesting this to be added to ES2021, which unfortunately is not possible as it breaks the existing upgradability for that version. I will have it estimated for consideration in ES2024
      Do you have a plan-B?
    • Natalie Hunter
      Feb 22, 2022
      The original request was to add it to the baseline structure datatype and then to have it updated the same way as the other baseline fields within that structure get updated. Then it would be used/displayed/historized the same way as the other runtime fields (i.e. on a display, in a report, etc).
    • Admin
      Jake Hawkes
      Feb 17, 2022
      Is the request to add this to the baseline structure datatype, so that it appears in every table?
      Is it also requested that it would be updated by the baseline krunch?
      Are there any other requirements on how this field would be used/displayed/historized?
      Would an alternative be to add it as a custom field outside of the structure, and then updated it with a Krunch Pipeline step?
